Canon ir2530i black screen
  • mramlawi
    • Jul 2011
    • 838
    Hi to all ,
    i have ir2530i when i turend it on the green led lighted but the scren is totally black without any motion to the copier.in my experienace this happen always in ir2520 its the dc board ,but i wonder why this happen is it a defu in machine or what,and theres no way to fix this pcb is theres any bulltin in this .i tried to checked all the fuese inside the board all it good.
    Distinguished road makes you jewel in rough
  • teckat
    • 16083
    Re: Canon ir2530i black screen
    The display is blank and the green led on the control panel is lit.
    If this issue occurs, check connectors J210 on the DC Controller and J8112 on the Main Controller. If one of the connectors is not seated properly there will only be 3 volts output from the Power Supply.
    The machine is powered on but the display remains dark. Nothing other than the Green Power LED comes on.
    Verified that 3.3v was present on J8125 pin 3 of the Main Controller.
    The solution in this case was to replace the Main Controller.
    iR2525 Main Controller FM4-8468-010
    iR2530 Main Controller FM4-8469-010
    iR2535 Main Controller FM4-8470-010
    iR2545 Main Controller FM4-8471-010
