e000018-0413-5
  • joescalante
    • Oct 2015
    • 9
    [Error Code] e000018-0413-5
    Got this code after replacing developing assembly. Will not run.
  • teckat
    • 16083
    Re: e000018-0413-5
    Is this an imagePress_?
    It has been noted that a faulty Patch Sensor Shutter Driver Motor has been the cause of the machine displaying an E018 with the 0x13 subcode.
    The Patch Sensor Shutter Driver Motor A.K.A. the Drum Patch Sensor Cleaning Motor (M135, M129, M117, M123) with current part number FL2-6138-000 which is the same for all 4 motors (one for each color).
    Swap motors to see if code moves over to that one.
    • joescalante
      • Oct 2015
      • 9
      Re: e000018-0413-5
      Will try switching. It is an Imagepress.
      • joescalante
        • Oct 2015
        • 9
        Re: e000018-0413-5
        Is there a way to test the motor before installing to see if it is working?
        • joescalante
          • Oct 2015
          • 9
          Re: e000018-0413-5
          So Now I get the code E000018-0313-5, I guess this is the fact that I changed from K to C positions.
          • joescalante
            • Oct 2015
            • 9
            Re: e000018-0413-5
            Don't know if this post went through previously but I the switch and got the code e000018-313-5. So am I correct to assume that this would confirm that it followed from the Black to the Cyan?
            • hasan5900
              • Dec 2015
              • 13
              Re: e000018-0313-5
              pls help error code E0018-0313-5
              • teckat
                • 16083
                Re: e000018-0313-5
                MODEL ???
                what were u working on before error
                on a imagePRESS C6000 / C6000VP / C7000VP
                E0018-0313--------------CYAN ISSUE
                swap motors--see if error switches over to other color
                x
                = 1:Y 2:M 3:C 4:Bk
                E018
                0x13 error code with the subcode 0x13 refers to the Drum Patch Sensor Shutter in when the shutter does not move to home position when initialized.
                1. Check the open/close operation of the film shutter by moving the drum patch sensor shutter solenoid (SL400 to 403) => Clean and re-install it if necessary.
                2. Check that the wire is set around the pulley => Re-install it if necessary.
                3. Replace the following parts if necessary.
                - Drum patch sensor shutter solenoid
                - Patch sensor shutter solenoid open sensor (PS401 to 404)
                The Drum Patch Sensor Cleaning Motor (M135, M129, M117, M123) depending on the color in question and/or the Patch Sensor Cleaning Motor home position sensor (PS215, PS206, PS202 and PS208) .
                --Faulty Patch Sensor Shutter Driver Motor
                --There have been cases where the whole Developer Rail Assembly needed replacement due to the bent developer unit saddle plate.
                If this is the issue, then the shutter will not come in to contact with the drive motor mechanism and therefore cause the error code. The part number for the Developer Rail Assembly
