IPF755
  • Iuri
    • Aug 2025
    IPF755
    Hello, i recently changed the printhead of mi IPF755 and about two days later i had Hardware Error 03800500-2f2f. In addition all prints are coming out with these thin lines. Anyone ever seen these lines before. They appear every 5cm from each other in all drawings.
  • mosey1100
    • Mar 2009
    • 143
    Re: IPF755
    This is what the Service Manual says about your error
    Hardware error.
    03800500-2F2F - Turn off printer, wait, then turn on again.
    03800500-2F2F - The non-discharge of the EVEN or ODD line (640-nozzles) is detected the 320-nozzles or more.
    Check the head management sensor and surrounding parts.
    Check that the printhead is installed correctly.
    Replace the head management sensor.
    Replace the printhead.
    • Iuri
      Re: IPF755
      Hardware error.
      Hello mosey1100, thanks for the reply. I installed the driver again and now its working fine.
      Thanks!
      • V-P
        • Apr 2011
        • 679
        Re: IPF755
        Maybe the 2 issues are connected but perhaps the thin lines might be due to paper issues (paper creating arch and so on).
        If they are connected it means that when you put your new head, it did not finish installation properly and as a result you should do a "band adjustment".
        The problem is that probably when you try to do a "band adjustment" it will pop up the (2f2f or 2f30) error.
        I would say :
        1. Update firmware first.
        2. Go to Sm and make a "Nozzle position check"
        3. Print a Nozzle Check from SM
        Of course you need to check the standard things like : Tubes have ink and purge is working fine (make the test of purge manually to see suction ability).
        hope it helps
        • Iuri
          Re: IPF755
          Thanks for the replies guys. I updated the firmware and it seems to be working fine. You were right V-P
