ir 550 duplex centering
  • jrivera
    • Aug 2025
    Have a copier that shifts about 5mm from front to back when duplexing. Whether i am placing originals on platten or using adf. Either double sided originals or 1 to 2 sided. Normal one sided copys are fine using platten or adf. Lead and trail edge are fine. I checked simulations and the duplex assy. to see if there was any way of of correcting this problem and couldnt find one. Am i missing something simple thanks for the help.
  • PoonKing5000
    • Jun 2008
    • 111
    I know its not the same machine but this might give you some info or head you in the right direction.
    http://www.copytechnet.com/forums/ca...ted-image.html
    • caronte
      • 16
      Are using letter on normal position, or legal?
      • jrivera
        duplex copies not shifting
        all including ledger.
        • caronte
          • 16
          ok you have to do some adjusment
          hablas español?, porque ese manual solo lo tengo en español
          • jrivera
            duplex
            poquito'
            • caronte
              • 16
              ok compa, bring me your mail to send it
              • OtherTech
                • Aug 2007
                • 94
                There is a software adjustment in service mode. Not sure from memory but should be in adjust, feed adj, reg2 (something like that). At the end of the duplex tray is a small motor that aligns every sheet. It is controlled by this adjustment. Hope this helps.
