I am getting this error code... E012-0001 it says to check itb motor and drum, disassembled and everything looks fine. Does anyone have an idea of solution? Also when i repower on after this error... Fixing unit does not seem to be heating up and machine does not get to ready state. ANy ideas? Thank You.
Error 012-0001 imagepress c1+ any ideas?
Tags: None
Re: Error 012-0001 imagepress c1+ any ideas?
Does drum & ITB move freely with power off _?
Check your door switches ?**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Update...
I changed door switches (switch from bypass tray door) from another C1+ and surely enough I am not getting E012-0001 anymore. Thanks to Teckat and all you guys out there. Now I need to find part no. for this switch.... for the life of me cannot find it on the parts catalog manual. Does anyone have it? Thanks.Comment
Update...
Manual Feed Open/Close Switch SW2 .
Part Number:FM2-0956-000
SW2 is illustrated below.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
