Canon Imagerunner Advance E000001-0002
  • aoe
    • 41
    Canon imagerunner Advance 8095.
    Hi, replaced upper and lower fuser rollers copier was working great for about a month and now getting
    E000001-0002, I now replaced all 3 thermistors. Has anyone replaced heater element on this model? Unit has 1 million copies on it. Thank you in advance.
  • teckat
    • 16083
    Re: Canon Imagerunner Advance E000001-0002
    Main Driver Pcb.> fm4-1083-000
    pico fuses
    Check FU19 - 12v
    J19 pin8
    Load for fixing power supply
    • aoe
      • 41
      pico fuses
      Check FU19 - 12v
      J19 pin8
      Hi thanks for the reply,
      the fault is not solid and happens after I run 100 legal size copies, letter works fine.
      I will check that though.
      Thank you.
      • vigour
        • Aug 2010
        • 1038
        That fuser has 3 thermistors. One main and 2 subs.
        • aoe
          • 41
          Hi yes replaced all 3. Thx
          • dan7777
            • Dec 2012
            • 680
            We have the newer model that gets that code every 6 months. We replace the upper fixing assembly. Have not tried the heater element but something in that unit goes out. I tried thermisters and upper roller. They have two machines but only one gets that code. On third upper fixing assembly.
            • aoe
              • 41
              Hi thanks for the reply, oem upper roller?
              Knocking myself out with this problem.
              • 20 year tech
                • May 2014
                • 577
                Have you checked your drawer connectors ?
                • aoe
                  • 41
                  Not sure I understand, paper drawers or connector at fuser. Thanks a bunch.
                  • 20 year tech
                    • May 2014
                    • 577
                    The fixing one also the one on the back frame it connects too, I think there was a tech pub on it. I am leaving my shop now but maybe someone else can post it for you.
