IR ADV C 2225I -E020-1360
  • gksapple
    • Apr 2014
    • 116
    [Error Code] IR ADV C 2225I -E020-1360
    Issue history
    *went to customer place to replace all drums
    *after part replacement
    first error e020-1160
    cleaned the laser unit and clear the mcon then resarted the machine
    second error e020-1060
    which is related to yellow drum so inserted the old drum then restarted the machine
    final error e020-1360
    action taken
    *replaced bk drum
    replaced magenta drum
    *replaced yellow drum
    *replaced the laser unit
    *replaced the registration patch sensor
    *replaced the itb
    *replaced high voltage pcb assembly (fm3-8175)
    *replaced the dc controller
    still e020-1360
    now all drums ,itb and pcbs are new
    help to solve the issue
  • MFPTech
    • 486
    Re: IR ADV C 2225I -E020-1360
    There is a TB, changing some SM settings will fix this, sorry, don't remember exactly what. Also update the Firmware before drum replacement.
    Sent from my SGH-I337M using Tapatalk
    • ss12
      • Jul 2008
      • 289
      I have the exact same problem,I'm going back with a laser tomorrow
        • 2621
        Field Remedy
        Tighten the screw of the inner middle panel.
        • gksapple
          • Apr 2014
          • 116
          Originally posted by skynet
          Field Remedy
          hi
          already check that screw it was in tight position ,even though i opened the cover and cleaned the connectors .
          error is not disappearing
          • gksapple
            • Apr 2014
            • 116
            Originally posted by gksapple
            hi
            is this will happen if toner hopper has any issue ?
            • hsrmms
              • Dec 2014
              • 69
              Issue history
              action taken
              *replaced bk drum
              *replaced the itb
              still e020-1360
              You have to make these steps:
              Clean Laser unit.
              Check the drum trail assembly "check attached file"
              Check the toner hoper "check attached file"
              Swap drum chip "put the old drum chip instate of new drum chip"
              upgrade the firmware.
              If you follow these steps I hope your problem will solve.
              Regards
              • MFPTech
                • 486
                IMHO it's just bad drums units. Think about it, everything is fine till you replace the drum. The first time i had this error i replaced the laser unit (i shouldn't! ) and the error went away. The same error happened on the same machine the next time i replaced the drum again. I tricked the machine somehow, put the old drum back and then the new one with the power on. In another case i changed the drums after powering the machine off. Have to confirm this power off/on condition when replacing drums. All that other stuff in the TB is just a bs in my opinion.
                • gksapple
                  • Apr 2014
                  • 116
                  hi
                  *problem found with laser unit (newly replaced also )
                  *swapped a laser unit from another machine
                  *issue solved
                  thanks for the support and suggestions
