:: ~ iR 5000 ~ ::
  • ~sIlEnT aNgEl~
    :: ~ iR 5000 ~ ::
    Hello Buddies,
    this is the firsy thread for me in here ..
    ok .. i have a problem and i really need help from you ..
    i have the following hardwares and softwares :
    1. Canon iR 5000
    2. Windows Vista
    3. Parallel Cable (LPT)
    4. Drivers For Vista And Xp For The iR5000
    and the problem is :
    * the printer is connected , the " use parallel port " checked as " YES " in the printer interface , the driver downloaded and installed correctly , but still says ,,, FAILD TO PRINT THIS DOCUMENT ..
    so guys all pleaaaaase help me up !!
  • welshman
    Technical Support Manager
    • Oct 2007
    • 91
    this model needs to be the ir5000n to print
    to check enter service mode *2+8*
    then look in copier
    then version
    look for boot
    if it says boot c then machine will never print its a copier not network ready
    if it is a c boot rom then costs to change it would not be worth the effort
    thats even if you can get hold a n boot rom
    sorry if this bad news
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      then look in copier
      then version
      look for boot
      Welshy's right...
      even though a parallel port is present if it's not setup as a printer it will never print.
