Canon irc5030 not adding toner
  • tomcatt
    • Jul 2010
    • 92
    Customer recently replaced toner and now the black toner is not being added to the developer assembly.Not sure if anyone has encountered this before
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon irc5030 not adding toner
    did you inspect the machine? What have you done so far?
    • tomcatt
      • Jul 2010
      • 92
      I have not done much yet. Next i will remove black toner and inspect toner add assembly.just thought i would get some ideas
      • vigour
        • Aug 2010
        • 1038
        most likely you need to change your black hopper. Have fun
        • tomcatt
          • Jul 2010
          • 92
          I thought so.I do have a parts machine to use......
            The sliding part under the hopper can sieze and block supply to the developer.
            • Canuck
              Tech Specialist
              • 1713
              Make sure they didn't jam in a 5045 toner cartridge. Are you sure it is a toner supply issue and not something else? If the patch shutter linkage breaks or dev prop gear or coupling breaks your can have density issues
              • zox-zg
                • Oct 2015
                • 9
                Take out add assembly. My coustomer hed something like this.
                tey change toner bat one pice of plastic broke and fell in and block the toner.
