E532
  • wassem
    • Aug 2012
    • 166
    [Error Code] E532
    hi everybody
    i have E532-8001 in saddle finisher v2 of the machine ir 7105
    i think this error is related to the movement of the stapler
    i think the the photos and the motor are working
    may the problem in the rail of movement , i lubricated it but no luck
    anyone has new idea,i will appreciate
    thanks in advance
  • wassem
    • Aug 2012
    • 166
    Re: E532
    Originally posted by wassem
    hi everybody
    thanks in advance
    can i use the function limited to stop the stapler only
    means stop stapler and use offset collating in the same time
      • 16083
      Re: E532
      e-532-8001 - stapler shift motor fault
      - stapler HP sensor fault
      - finisher controller PCB fault
      The stapler HP sensor does not go off within 500 msec after the start-up of the stapler shift motor.
      - Check the connectors of the stapler shift motor.
      - Replace the stapler shift motor.
      - Check the connectors of the stapler HP sensor.
      - Replace the stapler HP sensor.
      - Replace the finisher controller PCB.
      Limited Functions Mode
      * is default off
      Finisher Tray A/B: ON/ OFF*1
      Finisher Saddle Stitcher Unit: ON/ OFF*1
      Finisher Inserter: ON/ OFF*1
      Folding Unit: ON/ OFF*1
      Puncher Unit: ON/ OFF*1
      Stacker: ON/ OFF*1
      make sure your finisher door latch is secure
      Confirm the screws for the magnet that holds the door in place are tight and the door is closing properly.
      an interruption of 24v during finisher use can cause e532
      V2
      On the Fuse Box PCB, check pins 1, 2, and 3 on J418 and pin 1 on J416 for 24 volts. If there is no voltage present, press and hold the reset button on the bottom of the Relay on the Fuse Box PCB. If you then get 24 volts on J418 and J416 while holding the button, check the harness on J413 for continuity across pins 2 and 3. There must be continuity across the two pins or the Relay turns off the 24 volts to the stapler. If you are getting not continuity at that harness, check MSW5 and MSW6.
      • aco.bk
        • Sep 2012
        • 130
        Re: E532
        ir7105 V2.jpgCheck attached image.if gear 14 turns around axle error e532-8001 will appear.
