003-0202 and 002-0211 error codes on startup? c7000vp Imagepress
  • joescalante
    • Oct 2015
    • 9
    [Error Code] 003-0202 and 002-0211 error codes on startup? c7000vp Imagepress
    Thanks, to everyone, I got the sensor cleaned, got it put back together. Now I get two different new codes.
    003-0202 and
    002-0211
    They are not on the manuals list of codes so I have no clue where to turn.
  • teckat
    • 16083
    Re: 003-0202 and 002-0211 error codes on startup? c7000vp Imagepress
    003-0202 and
    002-0211
    Codes are in Service Manual
    QUOTE] Thanks, to everyone, I got the sensors cleaned, got it put back together. Now I get two different codes.
    -When a following error occurs, after taking appropriate action (remedy),THIS MEANS TO INVESTIGATE THE AREA/UNIT OF CAUSE-- be sure to turn ON the power, and then select the following to execute ERR: COPIER > FUNCTION > CLEAR > ERR. The error is cleared by turning OFF and then ON the power after ERR execution.
    E000, E001, E002, E003, E004, E013, E717, E719
    E002 = Error in temperature difference between the center and the edge of fixing roller
    x=
    1: Primary fixing
    2: Secondary fixing
    Fixing roller main thermistor:
    THM301(primary fixing),THM306(secondary fixing)
    Fixing roller sub thermistor:
    THM304(primary fixing),
    THM309(secondary fixing)
    Fixing external driver PCB: UN304(primary fixing), UN305(secondary fixing)
    Fixing duplexing feed driver PCB: UN311
    0x11 Error: software detection in temperature difference at fixing roller.
    When the software detects that the temperature difference between the fixing roller's main and the sub
    thermistors is 100 deg C or more for 1 sec continuously.
    1. Check that the fixing roller main/sub thermistors are clean and properly installed. => Clean and reinstall them if necessary.
    2. Check for any disconnection/improper connection of the following connectors.
    => Disconnect and then connect them if necessary.
    - fixing roller main/sub thermistor
    - between the fixing roller main/sub thermistor and the fixing external driver PCB
    - between the fixing external driver PCB and the fixing duplexing feed driver PCB
    3. Replace the fixing roller main/sub thermistor if necessary.
    E003 = Error in abnormally low temperature of fixing assembly.
    Error: low temperature detection of fixing roller sub thermistor
    When detecting temperature at standby/during print decreases by 30 deg C or more against the target temperature for 1 sec or more.
    x=
    1: Primary fixing
    2: Secondary fixing
    Fixing heater: H306(primary fixing), H300(secondary fixing)
    Fixing heater driver PCB: UN306(primary fixing), UN307(secondary fixing)
    0x02
    1. Check for any disconnection/improper connection of the following connectors.
    - fixing heater
    - heater harness relay connector inside the fixing assembly
    - fixing heater driver PCB (J4404)
    - fixing roller sub thermistor
    - fixing external driver PCB (J4192)
    - fixing duplexing feed driver PCB
    2. Check that the fixing roller sub thermistor is clean and properly installed.
    => Clean and reinstall it if necessary.
    3. Replace the following parts if necessary.
    - fixing heater
