hi friends
i have a canon ir3300 display " verifies the conexion networks"
Ensure network cable is plugged in, make sure IP address is input and correct, ping the IP address with the machine turned off you should receive a 'request timed out' message. Ping the IP address again with the machine turned on.
Change network cable check out the hub it is plugged into.
