Canon Ir3035 delay jam at PS4A when making two sided copies
  • tibbs
    • Aug 2008
    • 225
    Hello I have a canon with a jamming problem. It feeds but stops and says a delay jam at PS4A every time making two sided copies.
    Jam code 010A sensor PS4A. I have checked all the little black tabs 6 of them, they are all fine.
    Has anyone had this problem ? and if so what was done to fix this problem?
    Please any help would much be appreciated.
    Thanks.
  • mosey1100
    • Mar 2009
    • 143
    Re: Canon Ir3035 delay jam at PS4A when making two sided copies
    Thanks.
    You could check this out to see if it is causing your issue.
