E019 usually means the waste toner is full and usually changing the drum solves it. Not this time.
The manual says to clean or replace the waste toner full sensor. I tried that with no luck. I tried D.C. Controller
and that didn't help. I tried an Image Processor PCB and still no change. With the drum installed in the machine
and the waste toner full sensor free, I blocked and unblocked the sensor to see if there was any change. With it unblocked
the copier says to insert the drum unit. With it blocked it gives the E019 error. Guess it could be wiring to the Image Processer>?
