Canon ImageRunner 105
  • JrTech
    • Jun 2013
    • 217
    [Error Code] Canon ImageRunner 105
    Good evening CopyTechNet. I have a customer who I will not go into the long story but purchased 2 Canon IR 105 that come up with error code E602-033 which is bad segments of the HDD. I have done the 1+9 PO to check HDD and result is the same on both. Every dealer local and within 150 miles will not touch this machine as they have discontinued service and supplies. If I remove the HDD and all boards pertaining to the print feature, is it possible to make this machine a "Copier" only without causing any issues.
    Any Help in this matter would be greatly appreciated
  • teckat
    • 16083
    Re: Canon ImageRunner 105
    This printer will not function without HDD.
    You could have_
    1.Defective Boot DIMM.
    2.Defective RAM. (swap with a known working Boot DIMM) (swap with known working RAM). 3.Defective or Corrupt System Software (re-format HDD and re-load System Software).
    4.Defective HDD.
    5.Defective Resolution Switch PCB.
    6.Defective Main Controller. (replace HDD and perform full format then load System Software) (“Send” enabled models only) (replace Main Controller with a New Main Controller)
