Canon IR4025i fixing film problem
  • tartzu
    • Oct 2014
    • 13
    [Misc] Canon IR4025i fixing film problem
    Hey all,
    Need some advice on Canon IR4025. This copier has metal fixing film. And that metal film keeps brakeing. First film unit i replaced on 60k copys. Now 7 months later counter reached 100k and again fixing film broken. cant seem to find any reasonable reason why this keeps happening. Mayby anyone has some ideas or mayby there is some service bulletins for this kind of problem?
    Thanks in advance
  • slimforce
    • Jun 2015
    • 6
    Re: Canon IR4025i fixing film problem
    Did you just replaced fixing film only? Are you using the compatible parts? If you replaced the film only, did you use the right grease?
    • tartzu
      • Oct 2014
      • 13
      Could the problem be in whole fixing unit itself? Or is customer really just roughly himself destroing device which i hardly doubt.
      • tartzu
        • Oct 2014
        • 13
        pump
        • mosey1100
          • Mar 2009
          • 143
          Originally posted by tartzu
          Hey all,
          Thanks in advance
          You might have to replace the whole assembly. I had one file break at 19000 copies and I replaced the assembly.
