Ok I have a very strange one and have attached a scan. Anyway here is the problem, when I make a two sided copy the second side comes out blurred on 1/2 of the page. It's the rear side of machine that it appears on. Now you would think it has something to do with the duplex unit but if you make a one sided copy and take that copy and put it back in the tray it does the same thing. I have tried a different fuser assly and transfer roller and no difference. It also does this when you print a two sided print. For all you guys that were around when drums were selenium and you had moisture on the drum is what the copy/print looks like, but only on the second side. What I don't understand is if you are making multiple single sided copies they are fine.
Stumped after 42 years.
