IR4030 scan to email
  • campy
    • May 2012
    • 315
    I have a customer that had their IT person try to get the copier to scan to email. He changed the port to 465 and 587 and it still won't scan. He is using Gmail but he thinks it's a setting in the copier. My experience is limited to scan to file and have never done scan to email, so is there another setting I need to change?
  • mosey1100
    • Mar 2009
    • 143
    Re: IR4030 scan to email
    If you could get the error code you get when trying to scan it will help trying to figure it out. It is under Status Monitor/ Cancel > Send>Log highlight the email that didn't work then select Details at the top there should be a #xxx number and that will tell you what the issue is.
    • campy
      • May 2012
      • 315
      It immediately says resending.
      • madas
        • Aug 2008
        • 313
        Usually it will try a few times then spit out an error report, but you need to do what Mosey1100 said and check the error code in the send log.
        Should point you in the right direction.
        • davlast
          • Sep 2013
          • 7
          you can try go "system monitor" then "send" then "logs" press details on the one that is not going through and you should be able to see the error code
          otherwise have you checked that you have the correct DNS settings
          • kahyik23
            • Dec 2010
            • 15
            You mean before changing the port no 465 and 587is working fine. Have you change the port no at the machine at Service Mode 2.
            • campy
              • May 2012
              • 315
              Neither port # is working and yes service mode 2. I will check the log for error #.
              • kahyik23
                • Dec 2010
                • 15
                Normally gmail won't to send directly to gmail server. Unless the client have their own email server.
                • vickyhanif
                  • Mar 2014
                  • 14
                  Hi campy, you have to do 2 things so your scan to email (with gmail) can work.
                  1. Go to gmail settings and verify your account either by mobile or alternative email account.
                  2. In your gmail account settings you have to enable "allow less secure apps or devices". You can see the process on the following links. Now gmail usually block sign in attempts from less secure apps and devices. https://support.google.com/accounts/.../6010255?hl=en
                  Lemme know your experience.
                  Sent from my Infinix X506 using Tapatalk
