Imagepress color 7000vp. E077-0001-05
  • lilleputte
    • Jan 2013
    • 154
    Hi. I have done the following,
    Field Remedy
    1. If the same error code appears when the front cover is closed after work, check to see if the lever (B-E1) is shifted to the locking position; if not, shift it
    again. If the lever is in the locking position, go to Step2.
    Note: If the lever is locked at the wrong position, the lower portion of the cover may not be fitted completely although the upper portion does so. After the
    front cover is closed, be sure to make sure that both upper and lower portions fit completely to the main body.
    2. Refit the connector of the secondary transfer pressure release motor (M184).
    3. If the symptom still occurs, replace the secondary transfer pressure release motor with a new one.
    FK2-3124 Stepping DC Motor
    __________________________________________________
    I have not found any Bulletin on this error.
    Please come with suggestions
    Thanks in advance
    /Anton
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Imagepress color 7000vp. E077-0001-05
    Hi Anton!
    Inspect secondary transfer release motor and especially check for broken drive gears!
    Inspect transfer roller engagement and lubricate if necessary.
    • teckat
      • 16083
      Make sure the bearing to the Locking Lever on the Rear Side for the ITB Assembly is not missing.
      Try performing, Function > Copier > Install > INIT - ITB and ITB - EDGE .
      • lilleputte
        • Jan 2013
        • 154
        Hi. Thanks for your replies
        The machine works now , the problem I found was LEVER, RIGHT on the itb did not lock properly.
        Again many thanks and have a nice weekend
        /Anton
        • teckat
          • 16083
          /Anton
          welcome
