Ir adv-6075 e733
  • mramlawi
    • Jul 2011
    • 838
    Ir adv-6075 e733
    Dear all ,
    im facing a problem at my client shop that the machine gave me e733 also if want to enter the service mode it take time to comminicate with ms the machine i tried to make clear error the machine is freezed ,i disconnected the finisher,network card,cleaned the ram"s and still the same freezing and error e733
    Distinguished road makes you jewel in rough
    • 2621
    Re: Ir adv-6075 e733
    There's a tech publication that says upgrading the firmware fixes this have you tried that?
    • mramlawi
      • Jul 2011
      • 838
      Honeslty i didnt try yet the update ,but i wonder if the update same for iradv 6050 !! Cos i have the software update for 6055 thanks anyway waiting for more clearance .
      • mramlawi
        • Jul 2011
        • 838
        Can any one help what cause this error ?! I changed the dc pcb and still the same problem also i notice that when i enter the service mode version i can see the value is zero"s for dc version 0 main control 0 and all the list and its freezing
          • 16083
          SUB-code XXXX
          1.- I would try to reload latest Firmware/or replace the HDD
          Replacing Main Driver PCB (FM4-1083-000) has resolved the issue in some E733 cases,
          but in some instances the Main Driver PCB and Relay PCB (FM4-1086-000) had to be replaced at the same time.
          • mramlawi
            • Jul 2011
            • 838
            E733 -000 suddenly that happen and when u entered the service mode clicked the version and i found all the values zero and freezin the machine,i wonder how problem happend.
              • 16083
              HARD DRIVE or MEMORY ISSUE
              Not rocket science
              • mramlawi
                • Jul 2011
                • 838
                Not rocket science
                i tried a used hard disk for ir6055 and same error , and then i changed the ram's the machine didnt boot gave me a black screen
                • mramlawi
                  • Jul 2011
                  • 838
                  The problem solved after i changed the main pcb1, i wonder what made this problem suddenly
                    • 16083
                    STATIC CHARGES ? probably from tech servicing printer pcb's while printer is plugged into outlet/ or just from personal static not released thru a wrist strap
                    When you feel a static shock, you are feeling the generation of 3,000 volts of electricity.
                    You will feel the electrostatic discharge of 3,000 volts,
                    but smaller charges can damage electronic components, and you won't even be aware that a discharge has occurred.
                    There are a wide range of factors that can affect the amount of electrostatic charge that can build up as a voltage on personnel. Some common major factors include:
                    • The floor material and its electrical resistance, and resistance-to-ground
                    • Personnel footwear, especially the materials of the shoe sole and its electrical resistance
                    • Atmospheric humidity
                    • The manner in which a person walks, e.g. scuffing and friction of the shoes against the floor
                    • Actions of brushing against furniture, sitting and rising from seats
                    Static electric charges are separated whenever two materials make and break contact. This occurs with regularity between the shoe sole and floor material in walking action. Charge tries to dissipate and recombine where possible, but this cannot happen if it is prevented from moving by insulating materials. Charge builds up if the charge is generated faster than it can dissipate, and a high voltage can quickly result.
                    Many circuit-board components are sensitive to static electricity. Best practices to assure long life of your boards can be grouped into these three categories:
                    1. Reduce environmental static
                    If possible, and to the extent practical, maintain a heightened level of humidity around the control panel and other areas where boards may be handled.
                    • Ground your panel. A properly grounded panel helps prevent the buildup of static charges and can dissipate built-up charge from the operator.
                    • Avoid wearing clothing that easily generates or stores static electricity. Cotton or cotton blends are recommended, synthetic or woolen materials are not.
                    • Plastic items have the potential for generating a static charge. Keep all plastic and Styrofoam™ items away from any area where circuit boards are handled.
                    2. Ground yourself
                    When handling a circuit board, the operator should be properly grounded by (1) wearing a wrist strap connected to a grounding device, or (2) wearing heel grounders while standing on a static dissipative floor surface or mat.
                    In the absence of either, always discharge any static charge your body might have built up before handling a circuit board. This can be done by touching a grounded metal object—such as a grounded electrical outlet—and holding it for at least two seconds. If your panel is grounded, that will work too. Wearing an antistatic laboratory coat also can reduce the risk of static discharge to the board from clothing.
                    3. Handle equipment correctly
                    • Do not touch components, circuit traces, or connectors on a circuit board. Handle circuit boards by their edges. Never hold a card in the horizontal position by one edge; the resulting stress can damage the circuitry.
                    • After a circuit board or module is removed from a control panel, promptly store it in an antistatic protective bag or box.
                    • Do not store circuit boards in a stack or adjacent to each other because this also can damage the components.
                      • 2621
                      No worries about ESD anymore you can now buy cordless wriststrap ( only from China)
                      Its bullshit as this proves
