Canon C1+ developing rotary position problem.
  • hondacrxxx
    [CQ] Canon C1+ developing rotary position problem.
    Hello everyone. My machine is not working properly. It gives no error...
    Problem:
    Printing starts normally. 1-st developer moves on place drum get the color than rotator goes to the second position (2-nd developer moves on place drum get the color) - till this moment everything goes properly.. When the rotator moves to third position the rotator stops for a very short time and goes about 2cm further with strange sound. Then the rotator makes two or three normal rotations.
    Result :
    I have printout without cyan and black color(almost invisible) Probably the developing units have got wrong position against drum .
    What have i done:
    I have cleaned ps21 sensor, i've checked a rotary motor cogwheel, rotary cogwheel as well ( has every teeth). dc-con reset.
    Nothing works...
    The weirdest :for example: i left the machine for 1 hour off, after startup i get 2 normal printouts.... and than the same problem... (No rule)
    Any ideas ?
