Canon iradv 7260i
  • ss12
    • Jul 2008
    • 289
    Canon iradv 7260i
    Hi all just a question for you.Has anyone had issues with the drums breaking on the drive at the rear?we seem to have quite a few failing early with no clear pattern as to what's causing it.They can be a mixture of mAchines with some doing full bleed prints and others just regular office copying.I escalated this to canon but they didn't have any definitive answers,so I'm posting here to get any possible answers/solutions
  • teckat
    • 16083
    Re: Canon iradv 7260i
    Broken Drum Drive Coupling___?
    Perform the following to minimize occurrences:
    __Install the latest version of system software.
    __Replace the effected developing assembly and drum.
    __Change Service Mode Level
    1>COPIER>FUNCTION>AINR-OFF>0 to 1
    __Execute Service Mode Level 1>COPIER>FUNCTION>INSTALL>INISET-"x"
    __Execute Service Mode Level 1>COPIER>FUNCTION>INSTALL>TD-AD-"x"
    __Change Service Mode Level 1>COPIER>OPTION>FNC-SW>INTROT-1>200 to 50
    __Change Service Mode Level 2>COPIER>ADJUST>DENS>LLMT-PT-"x">0 to 1
    2>COPIER>OPTION>IMG-DEV-DEVL-VTH>0 to 1
    Execute__Settings/Registration>Maintenance>Adjust Image Quality>Auto Adjust Gradation>Full Adjust
    __Change__Settings/Registration>Preferences>Timer/Energy Settings>Low to High
    • ss12
      • Jul 2008
      • 289
      Thanks I'll give that a try
      • dan7777
        • Dec 2012
        • 680
        Canon is saying the drums are over 100% that are breaking. Has been happening since the 70xx series. They have done nothing about it I am aware of. I just know if I run test page 10 and one of the colors is missing that is the first place to look.
