everything I know about mc-08 maintenance cartridge
  • lan
    • Dec 2015
    • 3
    [Misc] everything I know about mc-08 maintenance cartridge
    I've been meaning to post there for a long time. I hope someone can save some cash with this info.
    search word stuff
    mc-08 mc08 canon ipf8000 maintenance cartridge reset image
    I am using a ipf8000, your mileage on other models may very.
    There are only 4 bytes on the eeprom when it is "new". I used a bus pirate to read/program the eeprom. It runs at 3.3 volts using i2c. i2c addresses are 0xa2 to write and 0xa3 to read
    I have attached a picture of the chip but if that doesn't work the pins are.
    with the chip side facing you and the pins pointing up, from left to right the pins are
    3v3. ground(the longest pin). data. clock. (if it doesn't work switch data and clock)
    some random things about it that might help someone
    the eeprom is 256 bytes
    do not use 5 volts
    the ink is conductive so if it over flows it can cause issues
    if you continue getting an insert maint cart message check that you are getting 3.3 volts the power source for the cartridge is on the main board. connector J3301 pin 4 as counted left to right
    If you are not getting voltage there is a tiny surface mount fuse above the J3301 connector that is probably blown. the easiest fix here would be to take that wire and find another 3.3 volt source.
    The main board has a serial number which it writes to several of the components. There is another eeprom( call it #2) (address 0xa4 and 0xa5 i think) on the same bus as the maint cart this eeprom(#2) is married to the CPU. When a new maint cart is plugged in the address from eeprom #2 is written to eeprom #1
    I think thats all the random stuff
    and finally the info you came here for:
    the 4 bytes are
    address data
    0x7d 0x55
    0x7e 0xaa
    0xfe 0xff
    0xff 0xff
    everything else is zero
    here is the full dump from a new chinese chip
    00 00 00 00 00 00 00 00
    00 00 00 00 00 55 AA 00
    00 00 00 00 00 00 FF FF
  • popeye67
    • Jun 2019
    • 4
    Re: everything I know about mc-08 maintenance cartridge
    Now, this is what I call a quality post. I know, I know, I'm a bit late to the party.
    • onlyinnewfoundland
      • Apr 2013
      • 235
      How many fills can you get on average? These things are "re-settable" in service mode if you reset it before it is at the full level.
      I've reset it for customers before while waiting on stock, but usually they change it shortly thereafter.
      • popeye67
        • Jun 2019
        • 4
