Canon iradv-c9070 send
  • mramlawi
    • Jul 2011
    • 838
    Hi to all,
    i have a question if anyone can help me please ,i want to let my client use the send to computer ,but i entered the counter the. Device configuration i didnt found send license ,is it come automatically or i must buy a license for this like old machine.
    at the same time i visited another client have ir-adv c9280 pro also without license but the send it working normally .
    Distinguished road makes you jewel in rough
  • teckat
    • 16083
    Re: Canon iradv-c9070 send
    When accessing the Counter Check URL in the imageRUNNER Advance device, the section will be missing if there is a Fiery controller attached to the copier device. When there is no Fiery device, the section in Counter Check will remain visible.
    • fr2au
      • Jan 2008
      • 20
      The send function for iR-ADV became standard not optional however the advance send kit (searchable PDF OCR) is still optional
      • mramlawi
        • Jul 2011
        • 838
        Aha thanka all , teckat the machine as us said its fiery thanks for ur info all,so is theres anything in service mode must enable it to let the send work cos i enter the send trying to find the pc not nothing appear.
        • teckat
          • 16083
          • To use the SEND function when the setting is for SSO-H, (Single Sign-On-H) when sending email, mail
          addresses need to be programmed against each user.
          If they are not, email cannot be sent. Note, however, that when sending i-Fax, the mail addresses set in the
          device are used.
          COPIER> DISPLAY> ACC-STS
          SEND = Display of SEND support PCB existence.
          Level.1= Details > To display whether there is PCB to support SEND function.
          SEND function can be used only when the PCB is mounted.
          Use case > When checking the connection between the machine and the PCB that supports SEND function
          Display/adj/set range 0 to 1
          0: Not mounted, 1: Mounted
          COPIER> OPTION> DSPLY-SW
          UI-SEND = Display/hide of send screen
          Level.2 = Details > To set whether to display or hide the SEND function.
          Use case Upon user’s request
          Adj/set/operate method
          1) Enter the setting value, and then press OK key.
          2) Turn OFF/ON the main power switch.
          0: Hide, 1: Display
          Default value 1
          Display Settings
          * Default Settings
          Default Screen at Startup
          Main Menu
          *, Quick Menu, Copy, Scan and Send, Send & Fax, Fax, Scan and Store, Access Stored Files, Fax/I-Fax
          Inbox, Secured Print, Web Browser, Workflow Composer, Remote Scanner, Print Server, Scan Lock Analyzer, Tutorial
          Open Status Monitor/Cancel: On, Off
          Default Screen (Status Monitor/Cancel)
          Default Status Type: Copy/Print
          *, Send, Receive, Store, Consumables
          Status/Log: Job Status
          *, Log
          Details: Print Jobs, Send Jobs, Receive Jobs, Copy, Fax, Forward, Local Print, Printer, RX Print, Print Report
