imagerunner 3570 as Network Printer
  • clussmates
    I'm having difficulty setting up the ir3570 as a network printer. I've configured the TCP/IP settings. When in service mode, I receive an OK/successful ping. I can also successfully ping the 3570 from any computer on the network as well as access the settings when I put the 3570's ip address in a browser. When accessing the settings page from a computer, I can get it to print the report. However when I try to print any actual document or file it fails. They all attempt to print, remain in Window's print queue for a minute, then times out and shows as error printing. The 3570's system monitor does not show any item under the print queue.
    I've tried many of the drivers (PCL5/6, Postscript, UFR, etc.) and none work. When installing the driver, the computers can find the 3570 just fine via ip address. I have whitelisted all the computers ip addresses in the 3570's settings as well. There is no password or department IDs set. I've tested on 32/64 operating systems, XP/7/10. Same thing every time. Been scratching my head over this since I think I covered everything. Is there something I'm overlooking?
    I am told this 3570 was previously only used as a copier.
    Also taking a look at the manuals I found online, I seem to be missing many options from my menu compared to the pictures show in the manual. Is there a way to perform a factory reset to restore the missing options?
    Happy holidays.
  • JoMaq
    • Jun 2015
    • 6
    Re: imagerunner 3570 as Network Printer
    same problem with me, please help, any idea?
    • kuby
      • Oct 2007
      • 1396
      Need to verify what version Boot Rom is installed in the machine. Needs to be a 'N'.
      • JoMaq
        • Jun 2015
        • 6
        Verified and its "N" boot Rom, still not printing.
        • sajith9544
          • Sep 2013
          • 5
          problem with ROM chip or HD..its only a copier ROM or hd...check in service mode it displays a 'BOARD' under copier, feeder.also check in copier -version-rom chip if it shows "xx.xx N" your machine ROM is ok..if it shows "xx.xx C" your machine is only a copier, reprogram your ROM.
          • sajith9544
            • Sep 2013
            • 5
            Happy holidays.
            • sajith9544
              • Sep 2013
              • 5
              change ur hd with a printer ready 3570 hd..if still have problem..clear ur machine ram " all ram clear"..if still,replace counter+serial no with printer ok machine....if still, check your mfc board
              • charm5496
                • 2387
                you need to go into service mode and check the version and style of the boot rom. In this case you are looking for an 'N' version behind the numerical value of the firmware for the boot rom. Without an 'N' version you cannot and will not print. Special firmware is NOT required on the device after the boot rom is installed on these models, and there is NO extra RAM to install either.
                • roho
                  • Mar 2009
                  • 844
                  I've had the same issue before, in my case a MMI clear was needed. You could also re init the printer completely, if you do indeed have a N rom
                  • JoMaq
                    • Jun 2015
                    • 6
                    Thanks sir, j
                    After clearing MMI as you suggested and verified the version, it shows now "C"! May I ask, how to upgrade it to "N"? Do I have to change the Boot Rom physically? Thanks again.
                    • charm5496
                      • 2387
                      yes, it is a physical change on the boot rom.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        My hunch was that someone tried to flash the "C" version with an "N" version of firmware, causing the display to erroneously show "N" until the MMI clear.
                        You can consider the "N" boot ROM a license, if you will.
                        • charm5496
                          • 2387
                          It has been a hot minute since I have done firmware on a 70 series Canon with the SST, but unless they are using a really old version of SST the process is basically automatic where you cannot change it from N or C. You should get a 'software mismatch' when attempting to do this:
                          Workaround :
                          There can be several different reasons for this problem. The most common is that the technician is trying to flash a machine with a N version of system software and there is a C version Boot ROM installed on the main controller board.
                          Another cause can be if the Boot ROM is at a lower version than is needed to load the system software. Update the Boot ROM to the correct version and type. Once the Boot ROM is at the proper version and type, the mismatch error should no longer occur.
                          Note: You cannot flash a C Boot ROM chip to a N Boot ROM chip, or vice versa. You must physically replace the Boot ROM chip.
                          I would think that someone tampered with the N boot rom personally
