Im facing a werid wide line on irc5180,i have checked the transfer belt roller and i also replaced the yellow drum with a used 1 17% life ,the wide line appear on test 5 only in yellow and also when trying to print or copy an a3 document ,i debout in laser cos betwen the wide line on left and right some white lines.ill post a pic ,thanks for the help .
also will be thankfull if some one found a solution for the background drums when it counters less then 50%
