special function> Long strip
  • anand8620
    • Jul 2012
    • 34
    [Misc] special function> Long strip
    How to use this function,
    special function> long strip
  • khattab.al.masry
    • 212
    Re: special function> Long strip
    Long strip: use of long strip original or long strip paper
    up to 630mm length paper is supported when DADF is used
    Related user mode: copy> special features
    Adj/set/opertaor method:1)service mode>level 2>copier>option>user>MF-LG-ST
    2)enter the setting value and then press OK key
    3)turn off/on the main power switch
    Display/aj/set range: 0 to 1
    0-off , 1-on
