X-1 DADF not feeding
  • cscce
    • Jun 2014
    • 156
    [Jamming] X-1 DADF not feeding
    I have Canon IRA c5030 with X-1 DADF. The feeder fails to pull documents unless I apply pressure to the adf cover. With pressure applied it feeds every time.
    If I turn the white gear at the rear of the adf it feels somewhat stiffer than the one on another c5030. I suspect a rusty clutch. But I haven't been able to find a service manual or part numbers for the X-1 DADF.
    I have found U-1, W-1 and many others. Are the repair parts for any of these the same as what is used on the X-1?
    Also, I haven't found any info on how to open up the cover to replace the parts. I see a couple of claws but I know there must be more.
    Thanks in advance for your help.
  • Jake2o
    • Dec 2007
    • 325
    Re: X-1 DADF not feeding
    Hi,
    Nope not got any info on a DADF with product code X-1. Mine stops at U-1 then goes on to AA1.
    Listed for the 50xx series DADF i have DX Colour Image Reader A1/B1/C1
    Main listed parts are P/U Roller, Sep Roller, Feed Roller.
    I am assuming you've tried replacing those.
    • Jake2o
      • Dec 2007
      • 325
      Yep found it. Here's your problem
      Canon using product codes on the machines that have no relevance to the service manuals
      Gotta love em!!!!!!
      Taken from the iR-ADVANCE C50XX BP_Rev1_1
      Best Practice Field Service
      • 20 year tech
        • May 2014
        • 577
        yep the tag will say x1 and the documentation says B1. the 5030 has the reversing adf versus the one path on the 5045-5051. the manual for it is in the service manual for the machine and the parts are listed in the parts manual for the machine.
        • cscce
          • Jun 2014
          • 156
          Many thanks to you and 20 Year Tech. Now I know which part number to order.
          • Jake2o
            • Dec 2007
            • 325
            Another Case closed.
            Glad we could help.
