IR 6055 code E000840-0001
  • amirtech
    • Jun 2025
    HI,
    please I change the fuser roller and I got this error message. please Help me.
    Sincerely thanks!!!
  • spectraindo
    • May 2008
    • 313
    Re: IR 6055 code E000840-0001
    Originally posted by amirtech
    HI,
    Sincerely thanks!!!
    Check the shutter, is it properly set ?
    There is a procedure to assemble the fixing unit, otherwise you got error.
    • Brian8506
      • 1664
      Did you lock down the shutter gears before disassembling it? Front and rear shutter drive gears have a slot to move the locking pin to before you take it apart.
      HI,
      Sincerely thanks!!!
      • laitang
        • Nov 2012
        • 627
        Refer attach document.
        Good luck!
