canon ir 5075 e733-001
  • ikbal
    • Apr 2014
    • 22
    [Error Code] canon ir 5075 e733-001
    Mesin not respons and not clear error
  • hamzan wadi
    • Oct 2014
    • 6
    Re: canon ir 5075 e733-001
    Udah coba ganti DC coitroll boss??
    Sent from my INA 001 SO using Tapatalk
    • teckat
      • 16083
      Did u remove Reader/Scanner cable when printer was up _?
      If so_ check the connection
      Accessory Power Supply
      FK2-3476-000
      Then_
      Confirm Multicast discovery is turned off in Additional Functions>System>Network>TCP/IP>Multicast set to off (0).
      • ikbal
        • Apr 2014
        • 22
        [QUOTE=teckat;504423]Did u remove Reader/Scanner cable when printer was up _?
        FK2-3476-000
        Ok brother i am try, tanks
