IR HDD Broken.. Need Help
  • blackcopy
    Hi Everybody,
    i'm newbie for this field, my customer has a broken HDD, dunno why. He wants me to fix it and return his machine to normally state. "Damn"..
    My Supervisor didn't tell me anyclue.. i'm so deperates..
    So.. Everbody.. Any Master.. Could you Help Me... Please..
    Thanks Before,
  • totoro
    • 568
    Hi blackcopy,
    Need a little more information before we can help you. What model IR are you refering to? Are you getting an error code? If so, what? What makes you say the HDD is broken? What does the screen on the copier say?
    Totoro
    Totoro
    • amuba
      • 30
      Originally posted by totoro
      Hi blackcopy,
      Totoro
      Thanks n2b, that is very interesting.
      Could you now try a little experiment, please?
      Switch on the printer with the new cartridges.
      Start the reset tool. See if it runs (you should be able to read the ink levels and print a test page).
      If that is ok, leave it running and re-install your old cartridges.
      Now see if you can perform a reset.
      You could also try only changing one cartridge at a time, because it may be that only one of them has been 'switched off'.
      Let us know how you get on.
      my blog free download Epson Blog - Epson colour laser printers, mono printers, laser printer, toner cartridge
      • totoro
        • 568
        Amuba,
        I'm a bit confused. What you've posted about has nothing to do with what I replied with about a broken HDD. Have you repplied to the wrong post?
        Totoro
        Totoro
