c5030, E733-0000
  • cscce
    • Jun 2014
    • 156
    [Error Code] c5030, E733-0000
    Canon c5030 displays the error E733-0000. Entering service mode the only button available is Copier, all others have disappeared from the screen. Going into function > clear > ERR (or anything else) the machine freezes. This started right after a P Print which only partially printed.
    Following the manual I replaced main controller 2, haven't replaced dc controller yet.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4955
    Re: c5030, E733-0000
    Did you upgrade the software??
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • cscce
      • Jun 2014
      • 156
      No, I haven't upgraded software or firmware. I recall seeing a post that mentioned a software upgrade fixed this error.
      • cscce
        • Jun 2014
        • 156
        I have SST but I need the c5030 system software. Unfortunately network security at the machine's location seems to be interfering with connections to Canon's servers. I can download from my office. I just need the link. On the other hand, I have 5 more c5030's. Can the software be copied from one of them to a pc and then copied onto the problem machine?
        Many thanks.
        • caini
          • Oct 2015
          • 27
          Think about what you done before the error occur. I remember once a broke a cable which seem contact the metal frame causing a similar issue.
          If you do not know. Try to boot the machine with unplug one cabel connecting to sensors or other componets each time form the DC control Board, if a different error code shows. Check the cable you unplug.
          • caini
            • Oct 2015
            • 27
            • cscce
              • Jun 2014
              • 156
              Problem solved. It was the Relay Board (FM3-7935-000).
              Many thanks to MrB for posting this solution back in 2014.
              • zoraldinho
                • Mar 2008
                • 4955
                Interesting. Good find!
