iRC3380
  • Blues Guy
    • Aug 2009
    • 216
    iRC3380
    Good day guys,
    I have 2 unit iRC3380 when I do PG 10 test 1 unit only the cyan color is totaly blank and the other unit the cyan & magenta color is blank. We have dismantle rear to check all the gear and clutch which is driving the developer unit seems all ok. Any idea guys that you have come across can share with me. Thank you
  • Canon345
    Re: iRC3380
    Thats very strange. Been working on these since day 1 and have never seen that.
    I would start looking at the laser unit. That is some really bad luck you would have two with bad units.
    A possible solution for you.
    The symptom was resolved by replacing the laser unit with a new one.
    1. If you experience this issue in the field, only one color is blank, there is the possibility it is due to faulty laser unit, hence replace it with a new one. When 2 colors, Y & Bk, or C & M problem occurs, assume it may be due to a faulty main controller PCB assembly(PDRM-EF-A), hence check the connections to this board.
    2. After replacing the laser unit, register the value written in the label packaged with the scanner unit in the following service mode, and adhere the label in the front cover.
    - COPIER > Adjust > LASER > FSLUT-Y1 to Y8
    - COPIER > Adjust > LASER > FSLUT-M1 to M8
    - COPIER > Adjust > LASER > FSLUT-C1 to C8
    - COPIER > Adjust > LASER > FSLUT-K1 to K8
    FM3-0003-000 LASER SCANNER ASSEMBLY
    • Blues Guy
      • Aug 2009
      • 216
      Re: iRC3380
      After change laser unit assembly and PDRM-EF-A still the same problem.
      Any thing else to change ?
      • Canon345
        Re: iRC3380
        I had a drum rod pull out of a drum once. Stuck into the back of the machine. Is drum actually moving?
        • ernesto
          • Oct 2011
          • 430
          Re: iRC3380
          Originally posted by Blues Guy
          Good day guys,
          HI,
          In reference to unit 2, you can try to exchange the most big sub-pcb on the main controller after that yellow and black will be blank, it means the sub-pcb is wrong.
          All the best
          • hidius
            • Jun 2015
            • 128
            Re: iRC3380
            change the developing unit. or check the coupling at the rear of the dev unit. if you turn the coupling and the shaft doesnt turn then order the new revised couplings. the old ones are black and the new ones are white with a pin
            • Canon345
              Re: iRC3380
              Your information pertains to C5000 series. The C3380 series uses a combined drum and developer unit.
              • hidius
                • Jun 2015
                • 128
                Re: iRC3380
                yeh sorry I just realised after I posted it but couldn't figure out how to delete it
                • hsrmms
                  • Dec 2014
                  • 69
                  Re: iRC3380
                  Good day guys,
                  Is it show any error codes such as E020-XXX??
                  • SAZ911
                    • Mar 2013
                    • 193
                    Re: iRC3380
                    Good day guys,
                    Hi Blues Guy,
                    Had this issue a few times here in Southern Africa. I got the solution from tekcat many moons ago. I have tried to find the same post to share the link but cant seem to find it, will keep checking though.
                    The solution for me was the developer clutch, as you have mentioned you have checked, and i don't mean to be patronizing but try swapping the clutches around to see if the issue moves to another colour. i had the same issue and the clutch looked good but wasn't.
                    good luck,
                    SAZ911..........
                    • SAZ911
                      • Mar 2013
                      • 193
                      Re: iRC3380
                      Good day guys,
                      Hi
                      Found the old post, hope this helps.......http://www.copytechnet.com/forums/ca...tml?highlight=
                      SAZ911..........
                      • Blues Guy
                        • Aug 2009
                        • 216
                        Re: iRC3380
                        Good day guys,
                        1st of all thank you guys for giving the advice on this machine problem.
                        I would like to update you guys that yesterday I try again to trouble shoot these 2 machine where I have change i) drum drive unit whole assembly (which taken from a good running condition machine including the
                        motor drive unit)
                        ii) developer drive unit whole assembly (which taken from a good running condition machine including
                        all 4 clutches and gear mechanism)
                        The result is still the same problem..........
                        • ernesto
                          • Oct 2011
                          • 430
                          Re: iRC3380
                          Have you checked sub-pcb boards....?
                          • Blues Guy
                            • Aug 2009
                            • 216
                            Re: iRC3380
                            I have change the whole main controller P.C.B together with the sub p.c.b. Other than that laser unit assembly and unit 1 assembly which comes together with drum unit and developer. All parts swap from a working condition machine.
                            • Canon345
                              Re: iRC3380
                              I think the only way this is going to be repaired is a big study of the manual and procedure. Sounds like we have helped here all we can.
