canon gp200
  • joetennisjoe
    • Aug 2008
    • 16
    canon gp200
    I got a E803, the manual indicates that it is either the scanner lamp or low voltage power supply. As soon as the machine is turned on, the scanner lamp does not light up at all, the error code appears a few seconds after turning off and on. I reset the error code in tech mode, but error comes back, do you think it is more likely the scanner lamp?
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    The lamps in NP's and GP's are fluro.
    Check the ends of the lamp for charring...if the ends have blackened then the lamp has blown.
