DADF - AD1(iR ADV 6055i) Feed size problem
  • aco.bk
    • Sep 2012
    • 130
    Dear,I`m facing a problem with DADF .When try to copy A4 DADF pick up paper and pop up message that there is no A5 paper in cassete,or if A4R is inserted machine want A3 paper .Already tried SENS-INT and TRYA4,A5R,LTR,LTRR in service mode but nothing happened.After RCON clear problem solved with A4(portrait) but not with A4R(want A3 ).any advice?
    In service mode,FEEDER-DISPLAY- TRY WIDE is constantly changing.
    102Total is 300K
  • Jaycat718
    • Oct 2013
    • 70
    Re: DADF - AD1(iR ADV 6055i) Feed size problem
    You might want to check the Harness that goes to sr8. I had an issue where scanning anything would result in an 11x17 size. No matter what size was loaded.
    FM3-7567-010 - harness
    WG8-5783-000- sensor
    A90 FM3-7561-000 1 DADF DRIVER PCB ASSEMBLY 1-PATH model
    A90 FM3-7562-000 1 DADF DRIVER PCB ASSEMBLY REVERSE model
    FM3-6210-030
    FM3-6210-030- Document Tray assembly
