ERROR CODE
  • tangishane24
    • Jul 2025
    [Error Code] ERROR CODE
    HI TEC, i having a problem with my canon ir 2200 it is showing err code 0000 51 0000 i have tried to clear it but to no avail.but after a coupples days it will become normal. i don't know what to do any help will be appreciated thanks
  • jamal121
    • 10
    Re: ERROR CODE
    E051-0000
    At start-up, home position is not detected when the horizontal registrationassembly is moved 100 mm in the direction of home position.
    Main cause The horizontal home position sensor is faulty. The horizontal registration
    motor is faulty. The DC controller PCB is faulty.
    Action
    1. Connector
    Are the connectors of the horizontal registration home position sensor and
    the horizontal registration motor connected?
    a. DC controller PCB (J304) <-> relay connector <-> horizontal registration
    b. DC controller PCB (J304) <-> relay connector <-> horizontal registration
    motor
    NO: Connect the connectors.
    2. Sensor lever (damage and interference)
    Sensor Is abnormal noise heard from the horizontal registration assembly in keeping
    with the motor rotation?
    YES: a. The horizontal registration assembly is out of place because of
    damage to the sensor lever. Replace the sensor lever.
    b. The horizontal registration assembly malfunctions because of the
    presence of foreign matter. Remove the foreign matter.
    c. The sensor is faulty and cannot detect home position. Replace the
    sensor.
    3. Horizontal registration motor, DC controller PCB
    Is the horizontal registration motor control signal generated by the DC controller
    PCB?
    J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
    YES: The horizontal registration motor is faulty. Replace the motor.
    NO: Replace the DC controller PCB.
