good day guys pleased help me on this cyan,magenta and yellow print are fine only on black color it print looks gray not black.
ir adv c5235 light image on black color
Re: ir adv c5235 light image on black color
on the rear frame make sure the the contact for BLACK is not knocked out of place
EXAMPLE PIC--Rear frame primary transfer roller bias contacts.
Side view of the same contacts
ITB primary transfer roller bias contacts on the ITB frame
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
thanks for the help sir. i already check the bias of primary transfer and also the primary transfer roller. and they looks in proper position. i also check it with multi tester.there is no glory without sacrificeComment
Try stopping the copy process so you can check the image on the drum.
If the image is good on the drum then the problem lies with your ITB.
If light on the drum then try swapping around the black/cyan laser.
DRUM
DEVELOPER
PATCH SENSOR
Check/Replace> 2nd Trans RLR on the Door & Springs ?
Using Generic Toner ??**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
the customer use original toner sir teckat. we just recently replaced the drum but still it doesnt solve the problem. i will yry to replaced the laser with cyan laser unit tomorow and i will informe you sir if it solves the problem i was also thinking of the developing unit but idont have same machine to try.
last time it gives error code e020-491 and we fixed it by toner stir in service mode on black color.there is no glory without sacrificeComment
Canon345
I had this same problem in a Color printer. Non canon product. It was dirty contacts on the drum and internal contacts like Tekat pointed out. After those were clean I ran a calibration and the machine was 100 percent.Comment
last time it gives error code e020-491 and we fixed it by toner stir in service mode on black color.Comment
imageRUNNER ADVANCE C5255 / C5250 employs 4 beam and C5240 / 5235 employs 2 beam.
this model has > Two Laser Units
Laser Scanner Unit 1=M/Y
Laser Scanner Unit 2=Bk/C
Hi to all,
There might be an issue in the toner supply system (Black hopper, develpping drive,...). So, what is the value of Dens-BK (in service mode > Display > Dens-BK) ?
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's fatherComment
