Canon IR-Advance-C5051i
  • sniper2g8
    • Jan 2013
    • 117
    [Misc] Canon IR-Advance-C5051i
    Print Quality Problems. the black printing makes Blurred, Fuzzy, as you can see in the attachment please help scan.jpg
  • V-P
    • Apr 2011
    • 679
    Re: Canon IR-Advance-C5051i
    Normally image adjustment procedures would fix the issue.
    Did you try to : calibrate (full) also color mismatch ?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5017
      How many prints have fuser?
      • dan7777
        • Dec 2012
        • 680
        Originally posted by sniper2g8
        Print Quality Problems. the black printing makes Blurred, Fuzzy, as you can see in the attachment please help [ATTACH=CONFIG]32022[/ATTACH]
        There is a lot of bad toner out there. Make sure it is Canon toner. I had toner bought from somewhere else that looked like it was in a canon box but on closer inspection of the box the small canon sticker was different. They made the box very well but would not fuse properly.
        • roho
          • Mar 2009
          • 844
          Does the same thing happen with color as well, or only black? I'd check the fuser first if it does that on all colors.
          • cscce
            • Jun 2014
            • 156
            Are scans also fuzzy or does this just affect prints?
