IR2200 jame
  • adel_nathan
    • Jul 2011
    • 103
    [Jamming] IR2200 jame
    hi to all
    i have problem in canon IR2200 jamming in two sided
    code is 0112 and 0212
    this code appear when copy 2 sided always no paper path
    and some times appear in 1 side also
    i clean separation and change the value of sep in service mode /adj / HVTR
    nothing help
    also i change paper size from A4 to A4r ..... but it's jamming also
    please help
    thanks
  • dan7777
    • Dec 2012
    • 680
    Re: IR2200 jame
    Originally posted by adel_nathan
    hi to all
    nothing help
    please help
    thanks
    Try an extra wrap on fuser exit flag. Some of those machines are so old they are hard to fix. I only have one or two left and we don't put them on a service contract. If you have a folded corner on duplex that is another problem.
    • Hopper
      • Jul 2008
      • 173
      Re: IR2200 jame
      hi to all
      nothing help
      please help
      thanks
      I have had that before with no explain reason. The only way I got around it was to unplug the additional trays #3 and #4.
      • adel_nathan
        • Jul 2011
        • 103
        Re: IR2200 jame
        thanks for replaying
        the jam is occurs before paper edge entering fixing unit
        that's mean after paper edge left drum unit it's curl up and folded
        not entering fixing unit
        i hope you understand me
        • Blizzoo
          • Aug 2013
          • 608
          Re: IR2200 jame
          Then your problem is on Fuser side. Check gears/film/pressure roller.
          • adel_nathan
            • Jul 2011
            • 103
            Re: IR2200 jame
            problem occurs before fixing unit
            • duwaynebrooks
              • Aug 2015
              • 43
              Re: IR2200 jame
              Is your transfer roller stuck ? Take out and clean.
              Also clean static eliminator and ensure it is correctly seated.
              • dan7777
                • Dec 2012
                • 680
                Re: IR2200 jame
                I had one doing that. Right as it entered the fuser. The guide has a locking tab that was broken. I folded up a piece of paper and put it in the one end to keep that guide in until I came back with another entry guide. If you have another fuser you could try that.
