Hi there, does anyone know the service pin for the advance 9070s? THX
Service Pin for ir advance 9070s Pro
Re: Service Pin for ir advance 9070s Pro
Default System Manager ID and Pin
Default System Manager ID is 7654321.
Default System PIN is 7654321.
This ID and Pin is also needed for the Remote UI as shown here.
How to Change the System Manager ID and Pin on the Control Panel:
1. Press Settings/Registration.
2. If Management Settings is greyed out, then Login as System Manager.
3. Press Log In, Enter in System Manager ID and Pin. Press Log In.
4. Press Management Settings > User Management > System Manager Information Settings.
Now you can remove or change the System Manager ID and Pin.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Thanks for the tip but the one I'm looking for is the 9070S, the weird one that links the Display directly into the fiery, so without Service Access it doesn't get in the service mode, or maybe is a way to bypass the OCE controller?
(Just Found the information now, if anyone needs is 675756)
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
