Settings/Registration > Preferences > Display Settings > Changing the Display Language/Keyboard on the Touch Panel Display
You can select the language/keyboard displayed on the touch panel display.
Remark; Even if the display language is switched, some display does not change.
Press  → [Preferences] → [Display Settings] → [Language/Keyboard Switch].
Select [Language Switch] from the list → press [Settings] → select the keyboard layout.
Mr teckat thanks alot for reply
i think you do not understand me
i mean what is the languages available to be downloaded to the m/c by SST
or by changing the software of the m/c
i do not mean the normal languages like english , french , italian , german
all LANGUAGE that's available
en=English
es=Spanish
de=German
it=Italian
fr=French
ja=Japanese
ko=Korean
CHnz/TWzh=Chinese
The following basic languages and a normal languages are installed in this machine at the
time of factory shipment.
Optional language support General area-
Basic languages> English, Japanese
Normal languages> German, French, Italy, Spanish
Asian area-
Normal languages> Simplified Chinese, Traditional Chinese, Korean
Besides these languages, you can install optional languages for which sales company prepared.
You can install basic languages, normal languages, optional languages, collectively 8 languages. The optional languages are prepared for in European area and Asian area.
The optional languages are shown below:
• European area
Bulgarian, Catalan, Czech, Danish, Greek, Estonian, Finnish, Croatian, Hungarian, Dutch,
Norwegian, Polish, Portuguese, Romanian, Russian, Slovak, Slovenian, Swedish, Turkish,
• Asian area
Vietnamese and Thai. The number of the installable languages. The number of the installable languages in this machine which are basic languages, normal languages, optional languages, collectively 8 languages.
2 basic languages and 4 normal languages are already installed. So you can install only 2 optional languages.
First, select the optional language to be downloaded in the Assist Mode and exported to the USB memory.
Optional language confirmation message appears in theSST Assist Mode.
The firmware of the selected optional language is exported to the USB memory.
The elimination of normal languages and optional languages.
There are 2 kinds of language modules. One is the basic module which saved in system area, the other is the indication module which saved in other area.
Usually the indication module is used in UI. If there is not the indication module, it is made from the basic module.
If you want to eliminate languages from this machine, you have to delete both of the basic module and the indication module.
You can delete the indication module only in the normal mode. The deletion of the basic module is only in the download mode. -To eliminate normal languages and optional languages, you select following service mode.
Copier > FUNCTION > CLEAR > LANG-CLR (Level-2)
By selecting this service mode, the indication module of normal languages and optional languages are deleted, then the download mode is activated automatically.
At this time, installing firmware set(including SYSTEM) without the deletion languages by SST or USB memory, the basic module is deleted. The basic languages(English and Japanese) are included in SYSTEM and these languages cannot be deleted
SST Optional language selection.
"Optional Language Setting" is added to "System Management". By default,"Don't download optional language" is selected.
When "Download optional language" is selected, up to two optional languages can be
selected.
The firmware of the optional languages on the list are excluded from Assist Mode necessary
firmware.
Assist Mode can be executed without registering the optional language firmware to SST. SST MENU.jpg
Optional language confirmation.
When either of the following conditions is satisfied, the optional language confirmation message appears when "Start" button is clicked.
Optional language is selected in the "Optional Language Setting" of "System Management".
Any optional language is installed to the connected machine.
Maximum number of the optional languages installed to the machine is two.
The optional language already installed to the connected machine is always selected, and it cannot be removed from the machine with SST.
Even if the firmware of the installed optional language is not registered to SST, it is counted as the installed optional language.
The number of the selectable optional languages in the "Optional Language Setting" is equivalent to the maximum number of optional languages.
The number of the optional languages to be added to the machine is equivalent to the maximum number of optional languages minus the number of the optional languages installed
to the machine.
Error will not occur even the number of the installed optional languages is greater than the maximum number of the optional languages.
In such a case, any new optional language cannot be added, but the firmware of the installed optional language is downloaded in the Assist Mode.
The picture shown below is the example of the case that Finnish is installed to the machine, and Danish and Dutch are selected in the "Optional Language Setting".
Only two optional languages can be installed to the machine and Finnish is already installed.
Therefore, either Danish or Dutch can be installed to the machine.
