how to extend validity of ssl certificate of canon ir 3570
  • princepriyu
    • Aug 2025
    [Misc] how to extend validity of ssl certificate of canon ir 3570
    hi i am using a CANON IR 3570 copier machine and i regularly use it from my web page to print documents from mailbox.
    recently when i updated my web browser it failed to connect my photocopier. finally i traced it was the error of expired certificate
    the issue is how can i extend my certificate validity of photocopier
    SSL certificate
  • teckat
    • 16083
    Re: how to extend validity of ssl certificate of canon ir 3570
    On some devices the Default Key from the factory is set to expire on the year 2014 or prior.
    Replace the Default Key Certificate by creating or uploading a new Default Key with valid date ranges.
    Set date to 2030
    In order to make changes to the Certificate Settings, all of the SSL settings on the copier must be disabled. Please check the following settings:
    1. MEAP - Press Additional Functions > System Settings > scroll down > MEAP Settings > Use HTTP. Set 'Use SSL' to Off.
    2. RUI - Press Additional Functions > System Settings > RUI Settings. Set 'Use SSL' to Off.
    3. Device Information Delivery - Press Additional Functions > System Settings > scroll down > Device Information Delivery Settings > Receive Limit for Each Function. Set 'Add Functions Settings Value', 'Dept ID', and 'Address Book' to Off (set all 3 to Off).
    4. E-mail / I-Fax - Press Additional Functions > System Settings > Network Settings > E-mail/I-Fax > Authent/Encrypt. Set 'Allow SSL (POP)', 'Allow SSL (SMTP Send)', and 'Allow SSL (SMTP Receive)' to Off (set all 3 to Off).
    5. IPP - Press Additional Functions > System Settings > Network Settings > TCP/IP Settings > IPP Settings. Set 'Use SSL' to Off.
    * You will need to reboot the copier in order for these changes to take effect.
    You should now be able to make changes to the Certificate Settings.
    • princepriyu
      the date has successfully changed,
      but still the problem exists
      new updated browsers cannot open the RUI
      Google chrome displays
      192.168.1.98 doesn't adhere to security standards.
      ERR_SSL_FALLBACK_BEYOND_MINIMUM_VERSION
      • teckat
        • 16083
        Chrome disabled SSL 3.0 in version 39 because of the POODLE vulnerability.
        It means that the website is using dangerously outdated version of TLS/SSL that is vulnerable to the POODLE attack. You can read more about that here: http://en.wikipedia.org/wiki/POODLE. You should contact the person (or whoever maintains that website) and ask them to update their TLS/SSL configuration.
        or>remove and re-install CHROME
        what ver of CHROME ??
        latest _ v49.0.2623.110m
        IE and Firefox do not have the issue.
        • princepriyu
          you are absolutely correct.
          the problem is only with Google chrome, (working good with Mozilla Firefox version 32.0.2 & IE)
          about the version of chrome, yes its v49.0
          i'v checked in mozilla firefox it DOESNOT work in the latest above 42.00
          any solution for this
          • teckat
            • 16083
            "DUMP THE CHROME"
            Fix SSL Connection error in Google Chrome - Try and Clear SSL State Option
