IR-2530i
  • gksapple
    • Apr 2014
    • 116
    [Jamming] IR-2530i
    while taking A4 duplex jobs paper is jamming (new machine , total counter 2000)
    jam code :010D (duplex feeding sensor)
    *A4R and A3 duplex is working fine
    Action taken
    *checked the S7 duplex feed sensor seems ok (connectors & flag springs)
    *swapped the duplex clutch cl4 to cl3 but still jamming is happening with A4
  • ernesto
    • Oct 2011
    • 430
    Re: IR-2530i
    What about solenoids...?
    • apoxi
      • Nov 2015
      • 45
      Re: IR-2530i
      Action taken
      Look for duplex clutch
      • gksapple
        • Apr 2014
        • 116
        Re: IR-2530i
        duplex clutch and reversing unit solenoid has no issue
        *clutch has been swapped
        *full reversing unit with solenoid has been replaced
        *still paper jam (010d)
        • ernesto
          • Oct 2011
          • 430
          Re: IR-2530i
          Is it an intermitent jam? In the irc adv 2225.... 010d jam code is caused by solenoid....
          • Blizzoo
            • Aug 2013
            • 610
            Re: IR-2530i
            Check the pressure between black plastic rollers (located on fuser) and the duplex feed roller on the RH door.
            • gksapple
              • Apr 2014
              • 116
              Re: IR-2530i
              [QUOTE=Blizzoo;509261]Check the pressure between black plastic rollers (located on fuser) and the duplex feed roller on the RH door.[/QUOT
              ISSUE RESOLVED BY CLEANING THE ROLLERS (FC5-1358-000) IN TH FIXING UNIT ASSEMBLY( TONER ACCUMULATED ON IT ) ,
