IPF 9000S
  • gksapple
    • Apr 2014
    • 116
    [Misc] IPF 9000S
    GETTING BELOW ERROR MESSAGE AFTER CUTTING THE PAPER (PLAIN PAPER ROLL)
    CANNOT CUT THIS PAPER .REMOVE THE PAPER AND CHANGE CUTTING MODE TO MANUAL
    ACTON TAKEN
    * REPLACED THE CUTTER BUT STILL SAME MESSAGE IS APPEARING AFTER CUTTING THE PAPER
  • hidius
    • Jun 2015
    • 128
    Re: IPF 9000S
    maybe change the media type in the media settings
    • gksapple
      • Apr 2014
      • 116
      Re: IPF 9000S
      proper media type is setted
      • V-P
        • Apr 2011
        • 679
        Re: IPF 9000S
        On the media menu there are some details and one of them is "Cutting Mode".
        Obviously smb switched it to "Manual Cutting".
        • hidius
          • Jun 2015
          • 128
          Re: IPF 9000S
          ive only seen this message come up when canvas or some other thick media is being used
            • 16083
            Re: IPF 9000S
            ? when did the message appear , before a roll change, after a roll change
            paper type change,
            did u perform any type of firmware change
            • gksapple
              • Apr 2014
              • 116
              Re: IPF 9000S
              paper type change,
              * i didn't perform any firmware update
              *while loading or changing the media and type its not appearing
              *after completing the cutting its appearing with all medias even plain paper also
              action taken
              *replaced the cutter but still happening
              *once the message appeared the machine requires restart
                • 16083
                Re: IPF 9000S
                Did u check for any fault codes _?
                Step 1: check to see if there is any open work or program, if so save them in order to avoid loss of important information. And then, go to Start and Turn off Computer to shut down your computer.
                Step 2: press power button of your Canon imagePROGRAF iPF9000s to turn your printer off. Unplug it from electrical outlet.
                Step 3: keep your printer at off mode for several minutes, during which the memory will lose.
                Step 4: plug your Canon imagePROGRAF iPF9000s back into electrical outlet and turn on it and turn on the computer. Now, the printer memory has been cleared.
                =:O > Remember that only by turning off and on your printer can not clear your printer because there is still electricity running through the cord connected to the wall outlet. You need to pull the plug out.
                • gksapple
                  • Apr 2014
                  • 116
                  Re: IPF 9000S
                  hi
                  *FOLLOWED ALL THE ABOVE MENTIONED STEPS BUT STILL MESSAGE IS APPEARING
                  *ONE NEW THING IS NOTICED THAT AFTER FINISHING THE CUTTING ,EJECTED PAPER FROM THE ROLL IS NOT GOING BACK TO PRINTING POSITION ,AS I OBSERVED THAT MACHINE IS NOT RECOGNIZED THAT IT CUTS THE PAPER ,THEN MESSAGE IS APPEARING.
                  MAIN CONTROLLER ??
                    • 16083
                    Re: IPF 9000S
                    hi
                    MAIN CONTROLLER ??
                    With NO FAULT LISTED
                    • V-P
                      • Apr 2011
                      • 679
                      Re: IPF 9000S
                      Try this:
                      Re load the paper and choose "coated" as paper type.
                      Than go "Menu / Paper cut" to cut a strip of paper.
                      See what happens
                      • Benjamin98
                        • Mar 2015
                        • 89
                        Re: IPF 9000S
                        Hi all,
                        I am having this same problem with an iPF8400:
                        I have updated the firmware to the latest but it made no difference at all. @Teckat the error code I am getting(last 4 digits) is 2019.
                        This machine is one of those that has the cutter blade on the carriage unit, it has been replaced but still the same error comes up. Interesting too, even if the cutter is removed when set to load the paper it does go through the motions but the error still comes up.
                        Does this machine have a cutter home position sensor? I cannot find anything in the manual that shows it.
                        Just to clarify, the error shows up when loading roll paper, I followed all the instructions on the screen. The machine checks the size and width of the paper and you can see the multi-sensor working (LED lights etc) then as the carriage goes back the paper moves back but not into the print position as per the original logger of this fault has said.
                        I tried to load manual paper as well but that wasn't even working at all, the carriage only went half way across the A4 OR A3 sheet and didn't even try to check the size etc.
                        Can anyone shed some light on this please?? Not sure what else to try next apart from replace Main controller..
                        Thanks in advance
                        Ben
                          • 16083
                          Re: IPF 9000S
                          Originally posted by Benjamin98
                          Hi all,
                          Thanks in advance
                          Ben
                          U receive message --can not cut paper ?????
                          The Flex cable sends the signals from the carriage assembly to the Main Pcb.
                          Replacing the Flex Cable ( QM4-8312-000 ) may resolve the issue.
                          or
                          Cutter Holder Unit
