Ir 2220i to a iR 3320i
  • brotherlarry
    • 55
    [Misc] Ir 2220i to a iR 3320i
    I have been asked if a 2220i can be converted to a 3320i. My question to the individual was why. I remember hearing whispers of Alchemists and Druids doing this. If anyone has insights please reply.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Ir 2220i to a iR 3320i
    Stop wasting your time right now.
    • dan7777
      • Dec 2012
      • 680
      Take a black marker. Cross out the 22 and write 33 above it. Simple.
      • MjarbarV2.0
        Adeptus Mechanicus Magos
        • Feb 2014
        • 68
        The impossible is easy - miracles take a little longer
        Let us not talk falsely now, the hour is getting late.
        • teckat
          • 16083
          ItRe: Ir 2220i to a iR 3320i
          There are jail cells waiting for u./ Or a job at McDonalds.
          Either one has a $1.00 meal.
          • brotherlarry
            • 55
            I agree to all the above. A Wizard of the Black Arts (mono-chrome) said that the secret is in the counter boards. My Question still is why.
            • teckat
              • 16083
              Neither the Counter Memory PCB nor the Serial Number PCB can be swapped to other equipment.
              The Counter Memory PCB keeps track of the total count, which cannot be erased or changed. The service counters are retained by the Main Controller.
              These counters can be reset manually through service mode. When the Counter Memory PCB must be replaced, after installing the new one, the new Counter Memory PCB learns the Total Count from the Main Controller.
              This is retained in SRAM on the Main Controller PCB and held active by means of an on board battery.
              Serial Number PCB is Restricted can only be obtained by contacting the Canon Technical Support.
              Counter Memory PCB Used in the Soft Counter Circuit is Available for Purchase.
              time to get back to real world
              • Lijodamodaran
                service manager
                • Sep 2014
                • 56
                Its possible to convert 2220i to 3320i .
                Sent from my LG-P715 using Tapatalk
                • teckat
                  • 16083
                  time to stop with the nonsense
                  • Canuck
                    Tech Specialist
                    • 1713
                    Jumper wire but I wont say where. That's fraud
                    • teckat
                      • 16083
