E004-0501 on IRADVC7260
  • rayjeek
    • Jun 2010
    • 239
    [Error Code] E004-0501 on IRADVC7260
    I replaced fixing film for E004-0501, cleared error but still comes up with same code. No temperature rise for fixing assy. Found a post from previous posts to be a faulty DC CON I/F PCB. Just wondering if anyone had replaced DC CON PCB to resolve such error code.
  • dan7777
    • Dec 2012
    • 680
    Re: E004-0501 on IRADVC7260
    On mine I also replaced fixing film and had same code. Looked at rear connector with drawer out and noticed a piece of paper jammed in connector at rear of machine. Busted out connector. I hope you don't have to replace left rear connector or you are a better tech than me. My boss helped me and it was the worst connector of all four as I have replaced the other three on this machine. No directions on how to do it. No temp rise suggests maybe you should inspect that. Also look at front connector. Maybe you will get lucky and just find a scrap of paper inside connector. If machine was running I would not suspect DC Controller yet. Check jam and if they had a jam right before error code could be paper in between connectors.
    • rayjeek
      • Jun 2010
      • 239
      Thanks so much, will check all.
      Sent from my D5503 using Tapatalk
      • rayaeek
        • Apr 2015
        • 15
        Problem solved. Tiny piece of paper found at the left rear connector( machine side)
        Sent from my SM-G901F using Tapatalk
        • rayaeek
          • Apr 2015
          • 15
          Exactly so. Thanks very.
