Noise ira7260
  • dan7777
    • Dec 2012
    • 680
    Noise ira7260
    Squeak noise is in right upper side. Motor 23 runs itb and black drum. I took itb out and could not find anything. Going back to look at drum assembly. Saw comments about somewhere it makes noise but not sure. Have had squeaks from black developer but was replaced two months ago. Machine runs all day and at 1.9 million clicks. Anyone who fixed squeaks, noise in this area 7260 color would appreciate help! Squeak starts when copy made. Forgot to do single color only but squeaks at motor 23 check.
    Re: Noise ira7260
    Developing drive asembly (Bk)
    Subject:
    Measure against the problem when noise occurs from the rear right of the main
    Symptom
    Noise may occur from the rear right of the main body at the time of operation.
    see pdf
    7260 noise.pdf
    • dan7777
      • Dec 2012
      • 680
      Re: Noise ira7260
      Subject:
      Symptom
      see pdf
      [ATTACH]32278[/ATTACH]
      Wow, thanks. I am going to do this tomorrow. Will report back first chance I get!
      • dan7777
        • Dec 2012
        • 680
        Re: Noise ira7260
        Got rid of squeak back right side but customer says there is still a noise I can not hear. Boss said he will go with me to listen. I can not hear really high pitch and haven't for years so it must be high. Took about 1/2 hour or so to lube behind gears, very easy.
