Hi everybody i need your help with the error code E751-1124 (IRC 5185), thanks for any help.
IRC 5185 / E751-1124
Tags: None
Re: IRC 5185 / E751-1124
E751-11Xx
Drum Unit / Faulty Connection of the Toner Receptacle .
X: reading=1, writing=2 x indicates color [Y=1, M=2, C=3, K=4]
Write error in the memory inside the toner cartridge.
***Check the toner cartridge connections or replace the cartridge.
In your case_BLACK CARTRIDGE \ & BLACK DRUM.
are u using Canon OEM PARTS**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
E751-11Xx
Thanks for the help.Comment
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
