Paper does'nt feed from either cassette . It makes a grinding noise so I think the motor is working. Pickup and feed rollers never move. What are common problems with paper feed units on these machines? Also tray lift works.
IR2200 no paper feed
Re: IR2200 no paper feed
Copper springs break item 13 Paper pickup mount assembly. Lift gear breaks. I hate feed problems in that model and happily I only have a couple left. Easiest way to fix it is to swap feed unit assembly out with one that works. Jam code may help. Does the bypass feed?Comment
