Canon 5035 Service Menu.
  • johnm@ucopier.com
    • Jun 2010
    • 46
    Does anyone have a decoder ring for the canon service menu?
    I am trying to determine drum life from the copy service report on the Canon Advance 4025 and a the canon advance c5035
  • teckat
    • 16083
    Re: Canon 5035 Service Menu.
    C5030 / C5035 / C5045 / C5051
    The following steps are how you tell the drum life percentages on the imageRUNNER ADVANCED 5000 series.
    Go in service mode
    * 2/8* Level 1>COPIER>COUNTER>LF
    LF shows life%
    • johnm@ucopier.com
      • Jun 2010
      • 46
      Is that # the remaining life or the used life?
      • cscce
        • Jun 2014
        • 156
        It's how much life has been used. I've seem machines where the life count was well over 100.
        • teckat
          • 16083
          on the C5051_C5045_C5035_C5030
          will display how much the Drum Unit is close to the end of life.
          *When a new part is set, the value becomes 0%.
          on the 4051_4045_4035_4025
          COPIER > COUNTER > LFK-DRM-LF
          The consumption degree (the using up of a resource) of the drum unit (Bk) is displayed by ""%"".
          *Clear the counter value after replacement by COPIER>FUNCTION>INSTALL>DRM-INIT.
          At the same time, the counter value of COPIER>COUNTER>DRBL-1>PT-DRM is cleared, too.
